Fan always on
Old Dec 23, 2007 | 07:12 AM
The Image's Avatar
Default Fan always on
My fan is always on. Is this normal. I've only just spotted it so it may have been like this since I bought it a year ago but I'm not sure. I've also had a problem with the heater not working when idling such as at traffic jams so could this be due to the fan?
Old Dec 23, 2007 | 08:33 AM
Default RE: Fan always on
What fan and on what year vehicle???????????????????????????????
Old Dec 23, 2007 | 10:36 AM
okdiscoguy's Avatar
You need to put what Mike asked for in your signature, or post it every time. Get to be a hassle asking every time.
Your cooling fans come on when your a/c is on, but in your case, you are low on coolant. If you bottle is full, you need to have the system properly bled. I take it when you say you lose heat at stops it means it stops blowing hot air and only blows cold. That is from not enough coolant being circulated through the system. No warm coolant to heat the heater.
Old Dec 23, 2007 | 08:16 PM
The Image's Avatar
That answers a lot of questions actually. My radiator has been running hot ever since I had a new one fitted in at a garage. I guess he didn't bleed it properly.
Thanks for the tip about the signature. I'll do it.
Old Dec 23, 2007 | 08:52 PM
Try bleeding the air from the system, that should bring the heat back to your heater at an idle.
Old Dec 24, 2007 | 06:59 AM
The Image's Avatar
Someone has told me that all I have to do to bleed it is run the engine with the water cap off and the air will work its way up. Is this correct?
Old Dec 24, 2007 | 01:50 PM
okdiscoguy's Avatar
If your cooling system is the same, there should be a plastic bleed screw in the RH side of your radiator. With the engine cold, opn the screw and fill through there. Start the engine, and keep filling it. Check it cold after a few starts...
Old Dec 24, 2007 | 06:02 PM
The Image's Avatar
Thanks very much
EstorilM
Oct 8, 2019 08:26 AM
jfall
Jan 23, 2013 07:03 PM
salers4
Freelander
Jul 21, 2007 12:48 AM
dcarsmith
Mar 8, 2007 10:16 PM
nuno106
Oct 30, 2006 03:31 PM
