fan clutch
Old Oct 18, 2009 | 09:09 PM
  #21
cranky's Avatar
Originally Posted by tweakrover
i have checked the electric fans and they work with the a/c on but i guess not from extreme heat. anyway i replaced the clutch and i was like a hurricane under the hood, all is good so far so i think that was the problem. the only thing is i used the heavy duty one and it seems to be engaged, or maybe it seems like it because it spins faster disengaged. does anyone have any experience with this. i thought the heavy duty engaged the same as the regular it just spun faster in both settings.
I think the HD one will give you less MPG.
________
Godess_N_Passion
Old Oct 18, 2009 | 09:39 PM
  #22
tweakrover's Avatar
im gonna ride it for a few days to see, i checked out some other forums on the topic and it seems that they stay noisy, if my milage sucks any worse that is i may exchange it for the 57
Old Oct 19, 2009 | 06:58 AM
  #23
antichrist's Avatar
went in for 5 min to see if they could get a fan clutch, no, big suprise
Why not? Were they out of stock?
Old Oct 19, 2009 | 08:15 AM
  #24
oh yea spike what did you attribute the rough idle to?
My rough idle was due to the failed fan clutch.
The engineers at Rover must know a thing or two about planet alignment.
Everything must be perfectly in tune, I can replicate the rough idle by removing the clutch fan and running the engine, put the fan back on...smooooottthhhh.
From what I understand a HD fan clutch with cycle on and off more frequently.
It kicks on at a lower temp to allow for more engine cooling.
So if you lived in Death Valley and towed a trailer up hill with the a/c on and your mother in law in the back seat you would want all the engine cooling you could get.
Old Oct 19, 2009 | 08:18 AM
  #25
Your temp sending unit for the e-fans must be bad, they should come on in a overheat situation.
Thought of this while eating breakfast this morning, we are assuming that your temp gauge is working correctly.
If your problem persists with the new fan clutch then I would replace the temp sending unit.
Old Oct 19, 2009 | 08:28 AM
  #26
tweakrover's Avatar
no i was checking for one listed under the disco, i didn't have the imperial #'s at the time
Old Oct 19, 2009 | 08:31 AM
  #27
tweakrover's Avatar
i'd have to put it in low range with the mother in law in the back, but if i were towing a trailer i'd make her ride in it
Old Oct 19, 2009 | 08:34 AM
  #28
tweakrover's Avatar
well the temp gauge seems to work fine, so if this new clutch works i'm not to worried about the electrics cause they work with the a/c. I'll just have to keep in mind i don't have that extra security
Old Oct 19, 2009 | 08:38 AM
  #29
Sounds like a plan.
Without the e-fans your a/c wont work while sitting in traffic but will work fine when going down the road, so I would not worry about it either.
Old Oct 19, 2009 | 09:43 AM
  #30
tweakrover's Avatar
the electrics work like champs with the a/c on so whatever kicks them on when its overheating must be broke, like i said not too worried about not having the extra protection, like you said spike it covered up your problem for who knows how long.
