Fan clutch bolt removal
Old Mar 2, 2016 | 07:52 AM
discorey's Avatar
Thanks for the suggestions. I ended up torquing them to 37 ft/lbs. Service manual said 37 for the crank pulley allen bolts. Seems snug, but not too snug. They were a pain to remove. When I broke one of the bolts, I pulled the breaker bar into my knee and left a nice handle-indentation. And, I did use the loctite. Now, onto the suspension.
Old Mar 2, 2016 | 08:44 AM
jamieb's Avatar
Originally Posted by jfall
I used a very long crecent wrench.
Put that on the fan bolt.
Then a 5 pound stubby hammer.
Whack the top of the crescent wrench from left to right or counter clock wise.
Works like a charm.
Do not hit the alternator pulley by mistake.
Put rags in the belts to jam them.
I tried to edit the title after but it would not allow me. I was referring to the four allen bolts holding the clutch to the fan, not the main 36mm nut.
Thanks!
Old May 31, 2017 | 04:26 PM
MPDano's Avatar
Works like a charm.
Sorry to hijack your thread, but to loosen the large bolt, it's counterclock? If so, dammit, no wonder I couldn't remove mine.
Old May 31, 2017 | 05:09 PM
jamestfl's Avatar
yes, counterclockwise / towards pass side. One good 'tap' from a bfh should do it. Then just spin it.
Old Jun 1, 2017 | 06:01 AM
mollusc's Avatar
Left to right is NOT counterclockwise.
This is a standard thread bolt. If you're standing in front of the truck, the fan bolt loosens to the left.
Old Jun 1, 2017 | 08:44 AM
Motorhead1's Avatar
Standard thread
Old Jun 1, 2017 | 09:48 PM
BS50MGSXR's Avatar
those four bolts were super on there for sure when i pulled mine off. i cant remember what i did to finally remove them, maybe soaked wd-40 in there and let it sit for days. something..
but just used blue lock tight on the autozone fan clutch bolts and used the OEM fan as i didn't like the ford fan.
MC04DII
Feb 27, 2014 08:43 PM
focusontheworld
Oct 21, 2012 01:00 AM
kenk
Jul 17, 2010 12:49 PM
rover1978
Sep 26, 2009 09:05 PM
