Fan clutch removal - D2 - HELP!!
Old May 14, 2010 | 09:33 PM
Eak69's Avatar
Default Fan clutch removal - D2 - HELP!!
Has anyone actually removed the clutch from the actual fan? I am in the middle of trying to fix this and can't get the two seperated.
I have only Saturday to do this seeing I have to get on the road Sunday.
Thanks!!
Old May 14, 2010 | 10:59 PM
NiteTrain's Avatar
just did my water pump but didnt have to remove clutch...you talking about those hex bolts that hold it on? I tried to remove one but they seemed REALLY tight..like they were welded in there! hit them with PB blaster about 4 times a day and see if that helps.
Old May 14, 2010 | 11:31 PM
Eak69's Avatar
No - that is to a D1 - I have a D2 without the (4) bolts - would make my life SOOO much easier if I had the bolts....
Old May 15, 2010 | 01:07 AM
NiteTrain's Avatar
my DII has bolts on the fan clutch
Old May 15, 2010 | 07:02 AM
lipadj46's Avatar
So does mine. I have not seen the ones without the bolts in real life, not sure how they connect or come off.
Old May 15, 2010 | 07:45 AM
The 03/04 had a different style set up.
Old May 15, 2010 | 09:27 AM
Eak69's Avatar
So back to the original question:
How do I get the clutch off the plastic fan when the clutch DOES NOT have the 4 bolts??
I have today only to do this so I really need help....
Old May 15, 2010 | 11:39 AM
NiteTrain's Avatar
sorry Eak, I kind of side tracked your original question. Have you looked in the RAVE manual?
Old May 15, 2010 | 11:49 AM
Eak69's Avatar
Yes - they dont show too much - but I didnt look through all 1500+ pages.
Ed
Old May 15, 2010 | 11:51 AM
NiteTrain's Avatar
just looked in my RAVE manual, it doesn't say anything about separating the two..maybe they're one unit? If I were you and needed it done quick I'd get on craigslist or start calling junk yards and find a complete fan/clutch.
this brings me a question i was going to ask which is on topic here...after I replaced my water pump I drove my rover a few miles without the fan..anybody know how far you can drive with just the aux electric fan? I know this will depend on outside air temp and driving conditions.
