Fanbelt Tension: How Do I Slacken?
Old Dec 7, 2007 | 01:50 PM
Panama Jack's Avatar
Default Fanbelt Tension: How Do I Slacken?
Maybe its Friday or I'm stupid, but I can't figure the RAVE technique for slackening the fan belt. I need to get at my alternator (suspected failing front bearing- replacement?), but the tensioner idler seems to resist my attempts at de-tensioning.
Any tips and techniques?
Old Dec 7, 2007 | 02:52 PM
Default RE: Fanbelt Tension: How Do I Slacken?
Should be able to put a wrench on the shaft that holds the pulley, and just move the pully to a loose position.
Old Dec 7, 2007 | 04:40 PM
98roverguy's Avatar
It takes some effort. Use the longest wrench/ratchet you can find. Cause Torque = Force X Distance
[sm=burnout.gif]
Old Dec 7, 2007 | 06:24 PM
Still don't get it- there's a 1/2" bolt that holds the tension idler pulley (and its spring housing) to the engine block. The tensioner works fine- leaning hard on the belt causes it to move ans take up the slack etc. Now, I want to "disengage" this tensioner. RAVE sez wrench the 1/2" bolt clockwise. This is weird, because that TIGHTENS it- and it's already tight.If I undo the bolt, nothing happens except that the bolt starts coming out of the pulley arm- the tensioner doesn't slacken or let off tension. What am I missing here?
Old Dec 7, 2007 | 07:43 PM
okdiscoguy's Avatar
There should be a bolt on the pulley. I felt a little cooped up in the house, so I went out and pulled my cowling and took a pic for you. The arrow points to the nut to turn clockwise to loosen tension.
[IMG]local://upfiles/5440/A87EA6778EAF4D95BBFD21908430FBD7.jpg[/IMG]
Old Dec 8, 2007 | 09:01 AM
OK, I get it- thanks Disc. I was attacking the bolt that holds the arm to the engine (hidden in your pic).
It's a balmy 80 degs down here in the Caribbean- no chance of being cooped up!
gregor
Apr 2, 2010 08:43 AM
whurst79
Jul 31, 2009 10:43 PM
C-MAN
Mar 7, 2009 03:57 PM
C-MAN
Mar 7, 2009 09:55 AM
Brad S1
Apr 9, 2008 05:22 PM
