Fast idle start up? normal?
Old Sep 11, 2008 | 10:08 PM
snowdude's Avatar
Default Fast idle start up? normal?
when i turn the key of my 2003 discovery S from a cold start, it idles at about 1.8k rpms for 30 seconds and sounds somewhat loud, then drops down to normal idle speed. is the normal?
heres the video of my starting it up, the sound changes a little because i move from the truck to outside. my camra fills up just as the rpms are going down.
http://www.youtube.com/watch?v=OC0ga-mpeHE
Old Sep 12, 2008 | 12:43 AM
HoustonDM's Avatar
Default RE: Fast idle start up? normal?
do you have CE light or SES light?? if so go get codes read
-Houston
Old Sep 12, 2008 | 01:30 AM
IDAHODISCO's Avatar
Thats what my 03 does! itend 's up at 800 rpm!! PRRRRRRRRRRRRRRRRRRRRRRR
Landrover's love the HEAT!
Old Sep 12, 2008 | 08:05 AM
Switzer's Avatar
If it consistent and settles back to idle rpm I would not worry about it. My 2000 Rover runs up to 1300 rpm at start up before settling back down.
Cheers,
Pete
Old Sep 12, 2008 | 09:04 AM
base's Avatar
The manual actually says this is normal..
Old Sep 12, 2008 | 10:55 AM
1200 RPM's is the norm. I would double check with your mechanic, that can be a little hard on a cold engine, especially an 03 with oil pump issues.
Old Sep 12, 2008 | 11:05 PM
snowdude's Avatar
now looking at it better, its 1.3k - 800, guess its normal, thanks anyways.
jacekk
Oct 7, 2013 12:25 PM
Disco Duckk
Apr 7, 2012 06:36 PM
VikingDiesel
Feb 23, 2009 09:01 PM
96SE7Disco
Mar 5, 2008 10:12 AM
westernsun
May 27, 2006 04:24 PM
