Fasteners for C pillar trim?
Old Feb 5, 2020 | 06:32 PM
Micmac's Avatar
Default Fasteners for C pillar trim?
Can’t seem to find anything online for these fasteners. I’m replacing the c pillar trim the one right behind the rear passenger door. I didn’t realize at the time I ordered that I also needed to replace the grommet fasteners that the piece mounts in. Anyone have any idea how to find parts numbers for these and other body fasteners?
Old Feb 5, 2020 | 07:16 PM
777AIA's Avatar
Try to search for it here (all you will find is the number):
cat.lrparts.ru/?category=73861
Old Feb 5, 2020 | 08:24 PM
Micmac's Avatar
Hmm can’t seem to find the tile with exterior trim
Old Feb 5, 2020 | 11:37 PM
razorkill12's Avatar
I changed both mine out and don't remember a grommet. Just 2 6 or 8 mm nuts holding them on. I used magnetic sockets so they would not drop down into the body (abyss).
Old Feb 6, 2020 | 04:35 AM
OverRover's Avatar
IIRC, to mount RH side: DDG100381 and LH side: DDG100391 it takes 3 Flange Nuts ( MXC8807 ) per side.
Old Feb 6, 2020 | 06:03 AM
Micmac's Avatar
Thank you! The flange nut is what I need. So I know it sound stupid but how do you go about mounting the new plastic piece onto the flange nut? Do the brass threaded bolts come off the trim piece? Trying to avoid breaking the plastic installing it wrong.
where did you buy the flange nuts?
Old Feb 6, 2020 | 06:13 AM
Micmac's Avatar
So do you access the nuts from inside the body from the plastic trim inside the door jamb?
Old Feb 6, 2020 | 06:14 AM
OverRover's Avatar
To mount the exterior trim finisher you need to remove the INTERIOR TRIM to get access to the nuts.
Re: the flange nuts (MXC8807) they are nothing special so take the trim to any local hardware store, Home Depot, Lowe's, etc and just match the threads.
Or just search the part number if you want to order them.
Old Feb 6, 2020 | 06:44 AM
Micmac's Avatar
Thank you! That was the missing piece of the puzzle
Old Feb 6, 2020 | 06:47 AM
Micmac's Avatar
Are there any tricks to getting that interior trim piece off? Don’t wanna have to buy a second piece of plastic
