Fault 4022 Reference earth connected to the ground
Old Jun 21, 2017 | 12:21 PM
JohnHZ3's Avatar
Default Fault 4022 Reference earth not connected to the ground
I just finished replacing both front hubs complete with ABS sensors. The two rear hubs and sensors have also been replaced. I have the three amigos plus the brake light on. The only remaining fault according to my Hawkeye scanner is: Fault 4022 Reference earth NOT connected to the ground.
Any ideas on how to remedy this? Thanks!
Old Jun 21, 2017 | 08:01 PM
disc oh no's Avatar
I've never seen this particular error, but it sounds like it's missing a ground on the ABS module. Look at a wiring diagram for the module. Check any and all wires that are grounds. You can back probe them at the module connector. Then connect a test light to battery positive and touch the test light to them. If it doesn't light, that wire may be your problem.
Igol
May 27, 2013 10:20 AM
robersonb
Nov 9, 2012 11:06 AM
RROJ
Jul 24, 2011 07:59 AM
kcirtap
Sep 26, 2007 09:39 AM
