Fault code P1175 Service Engine Soon
Old Jan 4, 2008 | 08:22 AM
nicknick's Avatar
4th Gear
Default Fault code P1175 Service Engine Soon
So before this light came on, about 5 days ago, the rover stalled sitting at a red light. It's never done that before. It started right up, and I went on my merry way. Two days later I went and got my emissions done, and passed. Then again, sitting at a red light, she spuddered a bit then acted just fine with a smooth idel. Then my wife had the disco and she called to tell me the Service engin soon light was on. Went then to auto zone to get teh codes, and I got a p1175 "Tune up". I changed the plugs and wires @ 50,000, and I got 80,000 miles on it now. Can anyone give me a little direction as to where I need to address this issue.
Thanks for any help you may give me, and I will fallow up with my resolve so that other can be helped in the future.
Old Jan 4, 2008 | 08:57 AM
Default RE: Fault code P1175 Service Engine Soon
The 1175 isn't on my list. When it stalls, how easily does it restart?
Old Jan 4, 2008 | 09:05 AM
nicknick's Avatar
4th Gear
It start right up. No issues. And there is not and "hard starts". I have had the light come on in the past, but that was due to the gas cap. And maybe my wife did not put the cap on tight enough, but the sall, an then the spudder acting where my red flag's that something is going on.
If the codes not on your list, that might explain why I could not find it in my web searches.
Old Jan 4, 2008 | 11:54 AM
Let me know if anything changes, and if it does, you might want to call me so we can talk more in detail.
303-862-7680
Colorado between 7 am and 8 pm
Old Jan 4, 2008 | 11:55 AM
geotrash's Avatar
It's possible that Autozone's scanner or the user screwed up. Sure is nice to have one of your own sitting in the garage- well worth the 80 bucks, IMHO. I would check the codes again.
Dave
Old Jan 4, 2008 | 12:21 PM
nicknick's Avatar
4th Gear
MMmmm, So What I'll try to do is find a different place (not auto zone) and get the codes rerun.
Disco Mike, you just made my Christmas list with your gracious offer. Much thanks. But I will try to do my due diligence first before bother you. Also I use to live In Highlands Ranch. I miss the views of the snow caps.
Old Jan 4, 2008 | 12:28 PM
S4poor's Avatar
ORIGINAL: Disco Mike
P1175 = System too lean (bank 2) Additive injector fuelling- lean limit exceeded RH bank.
Don't drive it IMHO.
Old Jan 4, 2008 | 12:31 PM
S4poor's Avatar
Entire list....
P Code
J2012 description
Land Rover description
P0101
Mass or volume air flow circuit range/performance problem
Load monitoring, the ratio of throttle position to air flow
P0102
Mass or volume air flow low input
MAF signal < minimum threshold, which is speed dependent
P0103
Mass or volume air flow circuit high input
MAF signal > maximum threshold, which is speed dependent
P0112
Intake air temperature circuit low input
Intake air temperature signal less than minimum threshold, after time for exhaust to warm up
P0113
Intake air temperature circuit high input
Intake air temperature signal greater than maximum threshold
P0116
Engine coolant temperature circuit/range performance problem
Signal differs too much from temperature model for longer than 2.53s
P0117
Engine coolant temperature circuit low input
Open circuit or short circuit to battery supply
P0118
Engine coolant temperature circuit high input
Short circuit to earth
P0122
TPS a circuit low input
Signal < minimum threshold
P0123
TPS a circuit high input
Signal > maximum threshold
P0126
Engine thermostat defective
Difference in radiator and engine coolant temperatures too small
P0130
O2 sensor circuit malfunction (bank 1, sensor 1)
Front sensor LH bank stoichiometric ratio outside operating band
P0132
O2 sensor circuit high voltage (bank 1, sensor 1)
Front sensor LH bank short circuit to battery supply
P0133
O2 sensor circuit slow response (bank 1, sensor 1)
Front sensor aged - period time too long/too short LH bank
P0134
O2 sensor circuit no activity detected (bank 1, sensor 1)
Front sensor LH bank open circuit
P0135
O2 sensor heater circuit malfunction (bank 1, sensor 1)
Front sensor heater LH bank - short/open circuit
P0136
O2 sensor circuit malfunction (bank 1, sensor 2)
Rear sensor LH bank stoichiometric ratio outside operating band (NAS only)
P0137
O2 sensor circuit low voltage (bank 1, sensor 2)
Rear sensor LH bank short circuit to earth (NAS only)
P0138
O2 sensor circuit high voltage (bank 1, sensor 2)
Rear sensor LH bank short circuit to battery supply (NAS only)
P0140
O2 sensor circuit no activity detected (bank 1, sensor 2)
Rear sensor LH bank open circuit (NAS only)
P0141
O2 sensor heater circuit malfunction (bank 1, sensor 2)
Rear sensor heater LH bank - short/open circuit (NAS and EU-3 only)
P0150
O2 sensor circuit malfunction (bank 2, sensor 1)
Front sensor RH bank stoichiometric ratio outside operating band
P0152
O2 sensor circuit high voltage (bank 2, sensor 1)
Front sensor RH bank short circuit to battery supply
P0153
O2 sensor circuit slow response (bank 2, sensor 1)
Front sensor aged - period time too long/too short RH bank
P0154
O2 sensor circuit no activity detected (bank 2, sensor 1)
Front sensor RH bank open circuit
P0155
O2 sensor heater circuit malfunction (bank 2, sensor 1)
Front sensor heater RH bank - short/open circuit
P0156
O2 sensor circuit malfunction (bank 2, sensor 2)
Rear sensor RH bank stoichiometric ratio outside operating band (NAS only)
P0157
O2 sensor circuit low voltage (bank 2, sensor 2)
Rear sensor RH bank short circuit to earth (NAS only)
P0158
O2 sensor circuit high voltage (bank 2, sensor 2)
Rear sensor RH bank short circuit to battery voltage (NAS only)
P0160
O2 sensor circuit no activity detected (bank 2, sensor 2)
Rear sensor RH bank open circuit (NAS only)
P0161
O2 sensor heater circuit malfunction (bank 2, sensor 2)
Rear sensor heater RH bank - short/open circuit (NAS and EU-3 only)
P0171
System too rich (bank 1)
Multiplication injector adaptive fuelling - rich limit exceeded LH bank
P0172
System too lean (bank 1)
Multiplication injector adaptive fuelling - lean limit exceeded LH bank
P0174
System too rich (bank 2)
Multiplication injector adaptive fuelling - rich limit exceeded RH bank
P0175
Multiplication injector adaptive fuelling - lean limit exceeded RH bank
P0201
Injection circuit malfunction - cylinder 1
Injector 1 open circuit
P0202
Injection circuit malfunction - cylinder 2
Injector 2 open circuit
P0203
Injection circuit malfunction - cylinder 3
Injector 3 open circuit
P0204
Injection circuit malfunction - cylinder 4
Injector 4 open circuit
P0205
Injection circuit malfunction - cylinder 5
Injector 5 open circuit
[font=arial]
[/fo
Old Jan 4, 2008 | 12:39 PM
nicknick's Avatar
4th Gear
So how do I address this and correct my problem?
P1175
Additive injector adaptive fuelling - lean limit exceeded RH bank
Old Jan 4, 2008 | 01:13 PM
geotrash's Avatar
Either you're getting too much air or not enough fuel to the right hand bank of cylinders. I'd start with a can of Chevron fuel injector cleaner to possibly cure the latter. If you're getting too much air, an intake manifold leak is a good possibility.
Also,I received the same code on my Nissan Maxima a couple of years ago and a new mass airflow sensor cured the problem. Incorrect airflow measurment by the MAF can cause the ECU to dial back the fuel flow, hence the lean condition.
Dave
