Fault code P1175 Service Engine Soon
Old Jan 4, 2008 | 02:24 PM
S4poor's Avatar
Default RE: Fault code P1175 Service Engine Soon
ORIGINAL: geotrash
Also,I received the same code on my Nissan Maxima a couple of years ago and a new mass airflow sensor cured the problem. Incorrect airflow measurment by the MAF can cause the ECU to dial back the fuel flow, hence the lean condition.
Dave
I agree 100%. I went through 4 MAF's now in my Audi. I would get the equivalent code for it until I replaced the MAF. I finally got fed up with the Bosch MAF so I converted it to a Hitachi MAF. Biggest pain with that is I had to remap my ECU for it ;-(
Old Jan 4, 2008 | 03:24 PM
ORIGINAL: nicknick
MMmmm, So What I'll try to do is find a different place (not auto zone) and get the codes rerun.
Disco Mike, you just made my Christmas list with your gracious offer. Much thanks. But I will try to do my due diligence first before bother you. Also I use to live In Highlands Ranch. I miss the views of the snow caps.
Don't drop a MAF into your truck based on this fault code, this is not the usuall code one would expect to see when a MAF is going down. Usually there are 2 other lean codes and a 734 type code indicating 3rd. or 4th. gear is out of ratio.
How is the truck running?
seamuspg
Dec 13, 2009 09:10 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
david1289
Nov 11, 2008 10:54 AM
Camdisco24
Sep 15, 2007 01:07 PM
