fed up with the abs system
Old Jan 7, 2008 | 12:11 AM
suntattoo80's Avatar
Default fed up with the abs system
ok im not fixing this abs anymore. i need to know how to switch the diff lock so i can have 4wd when i need it. i'v looked on the transfer many times i cant find anything to lock in. anyone have a pic???? p.s it's a 2000 disco 2
Old Jan 7, 2008 | 08:05 AM
Default RE: fed up with the abs system
What is wrong with you ABS, what repairs have you made and what codes is it showing? Then we will talk about CDL and how to do it. With out the ABS you won't have traction control, which takes away some of your traction that the CDL will give you.
Old Jan 7, 2008 | 09:41 AM
not sure about the code so far i'v replaced 3 of the wheel speed sensors. i will run today and find out the code and post it later.
Old Jan 7, 2008 | 11:02 AM
code it front left electrical circuit failure! yaaaaaaaaa!!!!!!!!!!!!
Old Jan 7, 2008 | 11:33 AM
I get the trio lights once a year, for the last 5 years, always a different code including speed sensors, had them cleared, nevere replaced parts and still running strong with no lights.
Try having them cleared and then drive it for awhile, usually the lights won't come back cause what tripped the fault in the first place was a momentary glitch and not a failure.
Old Jan 7, 2008 | 12:07 PM
mike they usally stay off for 1k miles then back on. i live in mass so 4wd is a need more than a want. would the cdl work if the light's are on? what would it do? would i have the norm one wheel on each axel spinning? would i have no better traction wiht it locked and TC not functioning?
p.s i had the light's turned off and they stayed off for the ride home have not driven it more than 7 miles.
Old Jan 7, 2008 | 03:32 PM
Call me when you get a chance.
303-862-7680
Colorado between 7am and 8 pm
DiscoTanB
Aug 17, 2015 09:43 PM
TRIARII
Dec 24, 2013 03:32 PM
NiteTrain
Sep 15, 2010 07:09 PM
Darover
Nov 2, 2007 09:10 AM
Darover
Mar 7, 2007 08:46 PM
