Felt Channel Window Seal replacement- Help
Old Mar 25, 2022 | 10:40 PM
Stratos993's Avatar
Default Felt Channel Window Seal replacement- Help
Hey Guys,
Started working on replacing my front passenger side felt window seal.
https://www.roverparts.com/body-chas...ls/CFE500580G/
I took the door card off, and am confused as to what to do next. Do I remove the window in order to access the channel to install the window seal in the track?
Thanks appreciate any insights!
Old Mar 26, 2022 | 12:19 AM
04disco2va's Avatar
The link you included is the front body door seal. Don’t have to remove the door card for that. that’s the seal on the body the door closes against.
If you are looking to replace the window channel seals, This is the felt seal the window glass slides on, left, right and top of door frame. Think I purchased from Rovers North. Only front is available new, which sounds like what your needing. Yes you’ll need to remove the window and frame to replace. It’s not as hard as it sounds. Youtube has videos. Hope this helps.
colemtd
Mar 25, 2022 06:48 PM
redwhitekat
Apr 2, 2014 01:37 PM
Dodger
May 3, 2011 08:37 AM
losinov
Apr 30, 2011 07:47 PM
ZMayo85
Apr 9, 2008 04:02 PM
