Fend Flare Arches done in Rust-Oleum Bed Liner Great Finish!
Old 08-21-2010, 01:02 AM
bosshogt's Avatar
Default Fender Flare Arches done in Rust-Oleum Truck Bed Liner Great Finish!
Hello all,
  • After a lot of research and testing from me. I decided to use spray on Rust-Oleum Truck bed liner on my wheel fender arches. I snuck over to the Jeep forums to monitor what did and did not work with spray on truck bed liner. Seems that Plastikote, & Duplicolor did not wear that well. Reports were that Plastikote peeled off in sheets after a short time. Rustolium worked well and was easily sprayed over for quick repairs.
  • I tested a few small projects on plastic parts using Duplicolor adhesion promoter. I also used Krylon Universal paint as a base coat before the truck bed liner. It all seemed to adhere well.
  • This past Wednesday on my working vacation I totally masked off my entire Rover taking almost 2 hours. I know all the work is in the prep. And used about 4.5 cans of Rust-Oleum Truck bed liner. I had about 30% humidity and about 75 degrees in WI at my folks summer house. I sprayed each coat about every hour on the hour, with 3 passes. Probably about over 8-10 coats +. It goes on thin because it is a spray can. See my pictures below.
  • The truck bed liner leaves a textured surface that is durable and will not rip off your skin if you brush against it. Its not as abrasive as Hurculiner from what I have seen. It still is somewhat abrasive. I hope it will dull over time. Now I am search auto paint stores to fine a UV spray on protect-ant to slow this from graying out over time.
  • Next is my rear ladder since the powder coat is bubbling and starting rust underneath.
The following 2 users liked this post by bosshogt:
GFranklin (06-10-2021), JUKE179r (06-11-2021)
Old 08-21-2010, 05:46 AM
smoverstreet's Avatar
Looks good! Someone mentioned to me to use something called Forever Black IIRC on the flares, but I think this looks plenty good enough for me. Did you end up using all 5 cans?
Old 08-21-2010, 06:56 AM
See, I would never get anything done because I would be in the hammock all day.
Old 08-21-2010, 07:28 AM
Bundu's Avatar
Banned
Nice job, I see you are **** about over spray
Better safe than sorry, its easier to cover up and remove plastic than it is to get over spray off.
Old 08-21-2010, 08:39 AM
03discoman's Avatar
FYI that stuff fades to a dull gray finish in the sun after 3 months
Old 08-21-2010, 10:44 AM
bosshogt's Avatar
Yeah I laid in the Hammock after a few coats...after the over-spray blew away.
I used about 4.5 cans. Now I'm calling around to some auto body paint shops to see if they carry a flat UV protect-ant so the bed liner will stay black. My car lives in the shade most of the day under a tree.
Old 08-21-2010, 11:50 AM
03discoman's Avatar
i'd pick up a bottle of hurculiner uv top coat....keeps thier product from going grey and dull.....
i bought mine on ebay for 16 $
Old 08-21-2010, 12:52 PM
bosshogt's Avatar
Ok 03discoman,
I checked that HERCULINER UV topcoat out. It looks good except I don't want it to be shiny/glossy. I like how this Rustoleum is satin/flat. So I will do it if that is all that is out there. There has to be a satin UV protect-ant that I can spray on. I would not be happy if this grayed in 3 months...I called rustoleum and they said it should stay black for about 2 years or more.
Old 08-21-2010, 01:12 PM
DiscoIIBrandon's Avatar
I like the flares...they shouldn't be glossy IMO either.
Old 08-21-2010, 04:14 PM
Camdisco24's Avatar
Forever black will fade pretty quick. Your best bet is to paint them:
https://landroverforums.com/forum/sh...ad.php?t=32736
Bedliner works great too, but paint looks just like stock. It comes down to what you like better.
Quick Reply: Fend Flare Arches done in Rust-Oleum Bed Liner Great Finish!
