fender flares
Old Feb 14, 2008 | 11:03 PM
girouardrover's Avatar
Default fender flares
Need a little advice. I have a 2003 Disco HSE. The fender flares are scratched and faded.
So, I ordered new ones from Atlantic Britsh. They should arrive in a couple of days.
Anyway, my question is: how do I replace them. Meaning do the stick on? are they bolted on?
Old Feb 14, 2008 | 11:20 PM
Luv2Disco's Avatar
Default RE: fender flares
I think they have double sided tape. Might have some screws not sure. Mine faded out too. The dealer refinished them under warranty instead of replacing them. A little light sanding and a sprayjob and they look great.
Old Feb 15, 2008 | 12:33 AM
thanks. they must have real strong tape because they seem to be on real good. not sure how I will get them off.
I guess just pull real hard.
What year and type is your disco?
Old Feb 15, 2008 | 08:58 AM
Use a heat gun/hair drier to remove your old ones, use a very strong cleaner to clean the paint surface before installing the new ones, and start from day one and keep some sort of a treatment on the new ones so they don't fade as fast.
Old Feb 15, 2008 | 12:20 PM
wesk's Avatar
Mike, what do you recommend to treat these so they stay protected?
-W
Old Feb 15, 2008 | 01:57 PM
Zonk872's Avatar
Similiar situation while living in Florida these past four years. The sun bleaches the black wheel arches out leaving a white like look. I tried Mother's Back to Black and every other product. The dealership said it would happen all over again if they were replaced. They recommended having them painted at a body shop.
From what I understand it's hard to remove them. I decided to sand and repaint. I used Rustoleum Plastic textured paint for plastic bought at Home Depot. It has the same texture as stock and makes them look brand new. How long will it last is a good question. So far it's been about four months and they look good. Even if it happens again I'll repeat the process. I just cannot see spending big bucks at a body shop or even buying/replacing them with new ones.
If your new arches fade- I'd consider this route. Good luck and keep them protected as long as they are in the sun- use protectant. I don't really use any protectant now that the arches are painted. Water/soap and back to new for now.
Good luck-
Old Feb 15, 2008 | 02:21 PM
jdelp's Avatar
Ditto to the above message. Those flares will fade again, they're expensive and hellish to take off and put back on. Buy yourself the $30 in supplies, tape up and cover your truck good and just sand and paint them. Looks good and you'll save yourself $300 and hours of grief.
mb8780
Nov 15, 2012 07:12 PM
Kraftyz51
Aug 13, 2007 10:56 AM
mb8780
Mar 21, 2007 08:18 PM
joelxa513
Nov 10, 2006 12:33 PM
edthediscoman
Oct 28, 2005 05:10 PM
