Fender Trimming
Old 11-11-2015, 11:05 AM
Alex_M's Avatar
Originally Posted by ZGPhoto
If you're going to run those truly AWFUL tires(they are terrible for almost every type of terrain except pavement), you might as well just use different full axles that are non-Rover that you can get 16.5" wheels for. Get a beefy FJ80 axle or the like with e-lockers and bam, you're golden.
Ehh, really? Jeez. They looked decent, but I hadn't looked up any reviews for them.
Originally Posted by WNYErikDiscoII
And the $300 worth of fender flares you will need after you cut.
Ah, who needs fender flares anyway? Haha
Ive had them custom made before. They were around $140/wheel
Was that $140 for the wheel said and done, or do you have to buy the wheel then have the hoop put on?
Old 11-11-2015, 11:28 AM
WNYErikDiscoII's Avatar
Former Sponsor
Originally Posted by Alex_M
Cost mostly.
Definitely doing gears first. Would axles definitely be required first just for street driving or just for off roading? She is mostly a daily driver, but this is working her way up to a full time off roader.
I do plan on keeping the same housing, I was just wondering if the ring and pinion were cross compatible.
We recommend upgraded axles on anything over 33". Unless you plan on accelerating slowly at 5mph every mile and never climb any hills, then you should be ok.
The R&P being cross compatible point is moot since you will need a much different ratio for the 37s anyways.
Former Sponsor
Per wheel said and done.
Old 11-11-2015, 11:46 AM
Alex_M's Avatar
I'm fine with driving her easily until could afford axles. Hell, cant afford any of it right now. Just spit balling really.
I'm just thinking if I could find an aftermarket ring and pinion cheaper for a Defender/P38/D1/RRC then that would be a great option. Actually, I already have, so I'm just checking.
Old 11-11-2015, 11:51 AM
Alex_M's Avatar
Originally Posted by drowssap
dont for get the 470 or 512 gear need to move them
No need to go that low. Going from 32s to 37s is approx a 15.7% increase and going from 3.56s to 4.11s is just a hair over 15.4% difference, plenty close enough. The only change in engine/trans/transfer case/driveshaft stress at that point (other than that .3%) will be the weight of wheel/tire and the offset.
Old 11-11-2015, 12:04 PM
Former Sponsor
Where have you found it and what brand is it?
Old 11-11-2015, 12:25 PM
ZGPhoto's Avatar
Toyota.
Old 11-11-2015, 12:45 PM
Alex_M's Avatar
It's on eBay shipped from the UK. Prorally nor super high quality, but this is a tight budget build and... I kinda like testing the limits of cheap parts for ****s and giggles.
Old 11-11-2015, 01:11 PM
Former Sponsor
I guess...... Just don't get in my group when we go out wheeling for a day.
Old 11-11-2015, 01:12 PM
ZGPhoto's Avatar
I'm sure the guys you'll eventually do trails with at events will appreciate that when they're pulling you a couple miles off a trail
Quick Reply: Fender Trimming
