Fiberglass A pillar trim
On the advice of somebody here (I forget who) I bought the fiberglass a pillar trim out of maylaysia as offered on eBay. $100 bucks for a set .These things are the ****. Half the price of OEM and I bet you could run over these with a tank. Perfect fit .look great. Wear like iron . I am a happy boy
I don't like that idea of using screws. I just used the tape because it's the same stuff holding the fender flares on. Pull about 1/2" of the tape cover down and fold it under before installing. Put the trim on and insert the 3 connectors near the door. Then get a small pair of needle nose and pull the trim away from the glass and grab that little folded piece and pull away.. push it down good and call it good.
