Filler Neck Seal at Gas Tank
Thanks for the lead Coors. Unfortunately, looks like that recall was only on a few years of D1's. I ended up siphoning some of the gas out of the tank; since I just filled it up 30 miles before this happened. I then used brake cleaner and cleaned/dried the area off and tried to weld the two pieces together with my soldering iron. After that I took some plastic and melted it onto the seam to beef it up some. Then for good measure scuffed it up with sand paper and put JB weld over the area.
Attempt at rewelding the factory seam:
Adding some more plastic on top with the soldering iron and a plastic hangar:
Seal it up with JB Weld:
I'm hoping this works. If not I'll just go buy a new one. Just a bit short on $$$ at the moment. Just took it off jackstands after replacing MAF, front diff, resealing rear diff, put on new headlight adjusters, and replacing the front oil seal. Starting to think this thing likes to be broken.
