first oil change since purchase and ticking seems louder??
Old Feb 24, 2012 | 12:05 AM
rimasco's Avatar
Default first oil change since purchase and ticking seems louder??
I had to go with Mobil 0w40.. I know I was supposed to use the Rotella T6.. anyway.. why would an oil change do this?? I was thinking the tapping was the flex plate issue.. does this new symptom help diagnose the underlying tap? PS where is the SAI on this year? its not on the passenger side fire wall?? thanks brothers
Old Feb 24, 2012 | 04:40 AM
The 0W40 choice would be for a very cold area, but the 5W40 T6 or the 15W40 dino cousin work well in many areas. Does noise start at cold start, or get louder as engine warms up? Have you done a mechanical oil pressure gauge test?
Maybe you don't have the SAI system? See attached, the parts are kind of hard to hide, and should be easy to find if it is fitted with one. Of course, if a pre-owned vehicle, parts could have been removed by a POET (previous owner - exceptional turkey)
File Type: pdf
Old Feb 24, 2012 | 08:53 AM
If you have a tick, heavier oil will just be a bandaide and not fix a thing. Are you mechanical enough to follow directions and find your tick?
Old Feb 24, 2012 | 11:35 AM
rimasco's Avatar
LOL Buzz, thank you, I used that from the RAVE.. this SE doesnt have SAI.. am I better off without?? less to worry about?? yes yes?? It starts ticking after warm up..
Mike, I havent been totally under it while running.. and its raining over here today.. the tapping seems like its coming from underneath right behind front tires??
Old Feb 24, 2012 | 03:01 PM
Yes less to worry about. But cheaper to fix than some other potentials.
Old Mar 2, 2012 | 09:26 AM
Nick82's Avatar
3rd Gear
I am having the same problem with my d2 . @mike i would love to here what the fix might be !
Disco5oh
Jun 12, 2015 06:22 AM
john65b
Oct 10, 2013 05:00 PM
Nikkiwi
Feb 20, 2013 06:32 PM
collin Barrows
Aug 28, 2011 07:13 AM
2000 Disco II
Jul 25, 2011 08:10 PM
