Fix/mod removing studs for SAI bracket
For those of us with secondary air removing the upper intake is a nuisance because you need to remove the SAI tube from the heads. This is both difficult because of limited space and you have a good chance of bending the tubes.
This would be alot easier if LR had used bolts rather than studs. The simple solution is remove the studs and use bolts, it makes removing the upper intake a breeze.
Although this has been written up before, I had some difficulty in locating the information so here we go.
Notes:
This is easier with the intake off but could be done with the intake on. It will be more work and slower but you could do it, the studs are easy to get out.
The biggest challenge will be if there is enough room to double nut the stud and turn the wrench
Go easy when removing the studs they are pretty small if they bind,hit them with penetrating oil and go back in then out. Patience is your friend.
Remove the studs double nut and 2 10mm wrenches,mine came out with no drama
Studs that are coming out
Nuts doubled up note the orientation
I am using Allen bolts,but you could use stand hex head
Size info M6-1.0 x 12
Allen
Standard Hex
Finally the bracket mounted, I removed the upper portion for clarity
Note mounted upside down
Complete piece - still upside down
Notes:
Allen
Standard Hex
The following 2 users liked this post by Richard Gallant:
JUKE179r (03-31-2020),
Sixpack577 (02-25-2020)
Richard Gallant (06-17-2020)
RoverMasterTech
12-28-2012 04:32 PM
