Fix/mod removing studs for SAI bracket
Old Feb 25, 2020 | 01:10 AM
Richard Gallant's Avatar
Default Fix/mod removing studs for SAI bracket
For those of us with secondary air removing the upper intake is a nuisance because you need to remove the SAI tube from the heads. This is both difficult because of limited space and you have a good chance of bending the tubes.
This would be alot easier if LR had used bolts rather than studs. The simple solution is remove the studs and use bolts, it makes removing the upper intake a breeze.
Although this has been written up before, I had some difficulty in locating the information so here we go.
Notes:
This is easier with the intake off but could be done with the intake on. It will be more work and slower but you could do it, the studs are easy to get out.
The biggest challenge will be if there is enough room to double nut the stud and turn the wrench
Go easy when removing the studs they are pretty small if they bind,hit them with penetrating oil and go back in then out. Patience is your friend.
Remove the studs double nut and 2 10mm wrenches,mine came out with no drama
Studs that are coming out
Nuts doubled up note the orientation
I am using Allen bolts,but you could use stand hex head
Size info M6-1.0 x 12
Allen
Standard Hex
Finally the bracket mounted, I removed the upper portion for clarity
Note mounted upside down
Complete piece - still upside down
Old Feb 25, 2020 | 02:59 AM
Frank4's Avatar
When I bought my first Discovery I had no idea they had SAI, every time I see an SAI post I read it and praise the Rover gods for not cursing me.
Old Feb 25, 2020 | 09:59 AM
@Frank4 yea it adds a lot of extra plumbing.
I need to see I can relocate the aluminum tubes on the firewall as part of this
Old Feb 25, 2020 | 11:07 AM
Best4x4's Avatar
Yep I always rip those silly studs off for bolts!!
Old Jun 17, 2020 | 03:19 AM
JUKE179r's Avatar
I finally did this and added the M6 x 12mm 8.8 bolts for the SAI studs. Easy peasy!
Old Jun 17, 2020 | 05:21 PM
Llamasayswhat's Avatar
I just did this on my engine rebuild, but I did it because I'm an idiot and forgot that the SAI and EGR valves had to go on AFTER the intake was on. I put them on the head before the intake and couldnt finish assembly.
Yanked those bitches right out
Old Jun 17, 2020 | 10:21 PM
User's Avatar
Am I the only one that slightly bends the SAI tubes to get it in and out? I've never had an issue, and I've only cracked one tube in maybe 10 HG jobs.
Old Jun 18, 2020 | 01:23 AM
@User I needed a lot of bend to get the intake clear so this was just simpler and reduces stress on the parts
Richard Gallant
Mar 5, 2020 12:00 PM
chubbs878
Dec 20, 2015 10:25 PM
robersonb
Oct 31, 2015 03:37 PM
RoverMasterTech
Dec 28, 2012 04:32 PM
ShortTom
Nov 4, 2010 08:23 AM
