flashing check engine soon light
Old Oct 29, 2018 | 04:43 PM
rmcc's Avatar
Default flashing check engine soon light
Hi all,
Was going down the road the other day and went to pass a car and noticed as soon as I stepped into it, the "check engine soon" light started flashing. I have never seen that one before. Anyone ever had this happen? The manual does not state a reason for it.
Thanks,
Rich
Old Oct 29, 2018 | 04:52 PM
Friday Night Disco's Avatar
You need a code reader to narrow down the issues
Old Oct 29, 2018 | 06:58 PM
Llamasayswhat's Avatar
Flashing CEL/service engine light is generally a hard misfire. Technical term is "catalyst damaging misfire" scan it and see which cylinders are missing and go from there
Old Oct 29, 2018 | 07:05 PM
mollusc's Avatar
Flashing CEL also means "stop the engine as soon as possible." Continuing to drive with a flashing light is probably going to result in needing some expensive parts.
Old Oct 30, 2018 | 06:39 AM
rmcc's Avatar
The problem is the light does not stay on long enough to put the code reader on it. Shows no code when checked??
Old Oct 30, 2018 | 06:46 AM
mollusc's Avatar
Yes, the code will be stored. The light doesn't have to be on to use a code reader.
Old Oct 30, 2018 | 11:09 AM
LR03NJ's Avatar
Yes its a bad misfire. Usually
stops blinking in few seconds and keeps the CEL steady on until it goes back to normal then the light turns off. Could be anything from loose plugs, ht wires or coil packs need replacement. It might not turn on for a while until the same driving conditions happened.
Champ
Mar 6, 2019 05:30 PM
oneblessedmess
Feb 1, 2017 02:21 PM
croller63
Dec 3, 2013 12:51 PM
Gilbert
Jun 8, 2009 11:33 AM
JRdisco1
Aug 5, 2005 03:43 AM
