flashing odometer
Old Mar 22, 2005 | 09:20 PM
discodataway's Avatar
3rd Gear
Default flashing odometer
I am considering buying a 99 disco II with 88k. The truck is extremely clean with descent service history, however the odometer is flashing. The manual says nothing about this (in relation to needing service). Does anyone know why this might happen and how to fix it?
thanks
Old Mar 23, 2005 | 12:31 AM
Bait's Avatar
Default RE: flashing odometer
The flashing odometer indicates something has been tampered with. Check with CarFax.
Old Mar 23, 2005 | 01:30 AM
3rd Gear
Carfax is clean and the vehicle is a 1 owner. The owner told me he had recently installed the factory brush guard & safari lights and the cluster had to be removed to run the wires into the proper spot. When he reinstalled the cluster the odometer was blinking. Can the dealer check this and/or repair the problem?
thanks again,
Brian
Old Mar 24, 2005 | 12:01 AM
Bait's Avatar
Brian,
The Dealer should be able to tell you what is going on. I would be very leary... Check your PM's.
Old Mar 25, 2005 | 05:40 PM
3rd Gear
the truck is at the dealer for pre-purchase inspection, hopefully they will be able to see if anything was tampered with. Thanks for your help
bcolins
Feb 22, 2014 09:22 AM
aarons02
Feb 25, 2011 06:34 AM
2005bigbody
Dec 19, 2010 09:47 AM
Havelockellis
Jun 17, 2007 10:52 AM
stephen
Apr 12, 2005 01:57 AM
