Flashing orange gears top left on dash
Old Apr 18, 2020 | 12:12 AM
Ivan0z's Avatar
Default Flashing orange gears top left on dash
Hello all my disco 2, 03 has the orange flashing gears along with a beeping alarm I can go in to 4 lo and back to 4 hi like nothing runs smooth no issues at all, just the flashing sign and beeping any idea what could cause this ?
thanks in advance
Old Apr 18, 2020 | 12:23 AM
Richard Gallant's Avatar
I did some searching and came up with this, you have an 03 So I do not believe the CDL is fitted.
Discovered in the end that it could be an indication that a bulb might have blown somewhere on the vehicle; on checking everything over discovered that the reversing light fuse had blown - problem solved.
Old Apr 18, 2020 | 12:32 AM
Ivan0z's Avatar
Yes correct it is not installed and thank you ill give it a good check tomorrow hopefully its an easy fix !
Chrisinhouston
Jul 1, 2020 04:39 AM
droddisco
Sep 15, 2018 06:54 PM
Micko
Dec 12, 2014 06:43 AM
gsgtsg
Jan 23, 2008 01:46 PM
valpo48
ROAMING WITH FRIENDS
Oct 3, 2007 06:38 PM
