Flashing transmission lights
Old Feb 28, 2010 | 12:25 PM
jneil's Avatar
Post Flashing transmission lights
After engine install and some self induced issues the D2 runs great except I now Have the two green manual and sport trans mission lights flashing indicating limp home mode per the manual. During the test drive I had a cooler hose fail and pumped out some of the fluid. I serviced it and repaired the hose but now have this limp home issue. Will a hand held reader clear this fault? Manual says 40 warm up cycles will but that not good for the trans as it in third gear only per limp home mode.-----Neil
Old Feb 28, 2010 | 12:32 PM
Charge your battery.
Replace it if it wont hold a charge.
When the trucks voltage gets to low the trans computer is the first one to be cut from power so it goes into "limp" mode.
Old Feb 28, 2010 | 12:35 PM
For sure, check and or replace the battery/alternator if you voltage is not between 13.6 and 14.4 volts.
Micko
Dec 12, 2014 06:43 AM
importdave
Sep 25, 2014 10:18 PM
Joe Pundzak
Feb 9, 2013 12:49 PM
jneil
Feb 28, 2010 08:39 PM
MallCop
Dec 17, 2007 07:46 PM
