hard shift into 2nd then flashing m and s flashing D and red shift lights
Old Sep 25, 2014 | 01:55 AM
importdave's Avatar
Default hard shift into 2nd then flashing m and s flashing D and red shift lights
Hi folks! I have a 2000 disco 2 with 117k. Runs beautifully, never abused. When I start out it revs a little high before slamming into 2nd. Then the m and s lights, D, and red lights on shifter flash for the rest of the journey. All reset afrer turning it off. This happens every time I drive it. I would live some advice. Please help!
Old Sep 25, 2014 | 03:45 AM
OffroadFrance's Avatar
Sounds like the xyz selector switch on the autobox gone wrong.
There's plenty of threads on the forum about it if you use the search. Have a browse of the RAVE manual also.
Whilst the lights are flashing normally you are stuck in third (get you home) gear totally. When you turn off the ignition sometimes it will reset but always returns quickly.
Old Sep 25, 2014 | 07:12 AM
drowssap's Avatar
have you checked the fluid?
Old Sep 25, 2014 | 10:50 AM
importdave's Avatar
Before I try anything else I will change the fluid and filter. I don't know the service history on this truck. I'm reading a lot about the xyz switch and just preparing in case I need one. It looks easy to change. But i do see the manual showing a tool used to position the selector shaft. I'm wondering if I can get the job done without the tool?
Old Sep 25, 2014 | 11:33 AM
The xyz switch is repairable you need some M5x15mm long screws (I recollect) and lock nuts first to replace the rivets that you'll need to drill out carefully, best is stainless screws. Full repair procedure is online in Aulro forum plus piccies. Have fun
The resetting tool isn't necessary provided the same switch goes back in exactly the same position so ensure you mark the position before removal. It takes about an hour or two plus the repair time, all up, say half a day. Penetrating oil is good first the day before.
Old Sep 25, 2014 | 10:18 PM
importdave's Avatar
Thanks! I plan to inspect and clean it. I scanned the codes and came up with p0722 output speed sensor circuit open. I'm wondering if those are servicible too??
MurphyPeoples
Mar 11, 2015 06:01 PM
collector87
Dec 19, 2014 10:54 AM
jeffmalone
Mar 13, 2010 09:23 PM
freeland02
Engine & Internal
Nov 25, 2007 04:44 PM
freeland02
Freelander
Sep 27, 2007 10:15 PM
