Flickering lights
Old Nov 1, 2019 | 08:29 PM
Ben Matheson's Avatar
Default Flickering lights
Noticed my LED flood lights flickering and figured they were just acting up. Noticed the dome light was flickering as well so something electrical is going on. Alternator is new and pushes out 13.8 to 14v per ultragauge.
Ideas where to start finding the problem?
Old Nov 1, 2019 | 09:15 PM
Best4x4's Avatar
Make absolutely certain all terminals/leads are clean. Also a good idea to check the ones in the fuse block under the hood.
Old Nov 4, 2019 | 02:03 PM
greisinb's Avatar
Do you see the flickering in other lit up electrical items like the odometer? Check at night when it's dark to make the flickering a little more apparent. I had the same thing happen to me it was a bad alternator voltage regulator which had just been replaced by the PO, it was the only bright and shiny thing in the engine bay so I was disappointed when I had to replace it so soon. Apparently even new alternators can be a little spotty (mine was rebuilt which is even more prone to problems) At any rate, I swapped it out and all of the flickering went away.
Old Nov 5, 2019 | 02:34 AM
JUKE179r's Avatar
I had a problem where for some reason my Disco only started when I turned the headlights on. After it was running, the interior LEDs flickered. The cause was a frayed positive battery cable.
Old Nov 5, 2019 | 06:30 AM
I'm tempted to replace both battery cables. Are people fabricating their own?
Old Nov 5, 2019 | 06:36 AM
Jason Feuerstein's Avatar
It's not difficult, but you will need a battery cable crimper, which can be expensive if you're only using it once. Or just try doing it with the ignition terminal crimper on a wire stripper, but some of us (*cough*) don't have the greatest hand strength.
notny41
Aug 2, 2016 09:55 AM
94svt50
Jan 24, 2015 03:36 PM
Bduncan26
Oct 26, 2012 12:48 PM
pdxdisco2
Dec 7, 2007 10:12 AM
katbri
Oct 19, 2006 01:39 PM
