Flooded!
Here in VA, a storm came through we got 4 inches of rain per hour. I have water up to the bumpers (not over them). What do I do when the water recedes? I planned on vacuuming it obviously but as far as starting, I dont want to do any more damage, than the water already has done.![Mad](https://landroverforums.com/forum/images/smilies/MMiQGA5.png)
http://imageshack.us/photo/my-images...sc00048hp.jpg/
ImageShack® - Online Photo and Video Hosting
Not all of the trucks have a snorkel either! So unless the waterline went up over your hood then I doubt you have much to worry about. But if you do have a 6 disk CD changer mounted under the front passenger seat (stock on some trims) then you may want to inspect it for damages.
Yes, because you did not stall out while submerged therefore your would have sucked no water in. If the water has reseeded give it a little bit to dry out and you will be fine. We drive threw water often in land rovers they are made for off roading and with that come creeks and streams. This forum is here to help you not lead you in the wrong direction.
Dude, You GUYS are awesome!.... water receded I waited a couple hours and she cranked right up...went to the car wash to remove debris from the undercarriage, running like a champ. I did get some water in from the sunroof (just damp, no standing water) will shop vac out tomorrow, we are getting a slow steady rain now...
I was a little worried but you guys came to rescue! A great bunch.
That was a lot water!
