Floor jack / jack stand recs for lifted Disco's
Alrighty, gotta figure out a floor jack and stands for Magpie -- Never had a lifted truck before so I don't know what'll work and what won't. Magpie currently has a 3"+ lift and has beefy tires so its.. high.
37" from ground to fender and about 18" from the ground to the chassis.
From what I can tell, most floor jacks max out around the 17-19" mark but i guess with some sort of an extension it might be ok..
Thoughts?
Thoughts?
I bought a Harbor Freight's Daytona 3-Ton floor jack #63183 due to its 23" max lift height for $179 with $20 off coupon. With a couple of pumps, I've got my Disco up high to crawl under her... with floor jacks in place of course!
Some say it's overkill for that price but I can afford it and it works well for lowered cars too.
I got a 4 ton floor jack at tractor supply on Black Friday year before last for $100. She's been great. Has a 24-1/4" lift I think.
For Jack stands, I'm still using a 3 ton set I got on Amazon when I first got the truck (stock height). I usually jack it up from beside the differential, remove the wheels, and set it on the jack stands at max height.
If you want taller, you've gotta increase tonnage for a jack stands. No two ways about it. Unless you build some 2x4 platforms.
