Fluid in console.
Old Jun 21, 2005 | 09:26 AM
nickvillaume's Avatar
3rd Gear
Default Fluid in console.
I have a 98 Disco that is making a water noise in the console. When I drive it sound like there is fluid sloshing around beneath the gear selector and differential lock selector. Any thoughts?
Old Jun 21, 2005 | 02:15 PM
mikemeyer0's Avatar
Default RE: Fluid in console.
it's prolly actually comming from your heater, you need to bleed air from your cooling system, you could have a leak in your cooling system too.
Old Jun 23, 2005 | 12:59 AM
Bait's Avatar
Nick,
Check your A/C drain tubes. They are probably clogged. They exit right above the trans, under the vehicle.
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
Evian
May 3, 2008 05:10 PM
