Flushed coolant = four amigos
Old 04-06-2020, 11:03 AM
DCDisco2's Avatar
Default Flushed coolant = four amigos
Yesterday I drained the coolant in my 04 DII, refilled with Prestone, and now I have the 3 amigos and the emergency brake light. I let it dry out overnight, no change.
Before I take it to the shop, any suggestions on what I might have screwed up? I know the wheel speed sensor connector is under the overflow tank, should I open that up and blast it with contact cleaner?
I already checked the brake fluid reservoir, full to max, float seems to work, no change when you unplug the sensor.
Thanks for any suggestions!
Old 04-06-2020, 11:09 AM
XRAD's Avatar
yes. start there. it does not take much to throw these sensors off. blow it out with compressed air, too. Antifreeze does not just evaporate easily. I had antifreeze in O2 sensor plug and it threw codes.
Did you spill coolant when filling the reservoir?
Old 04-06-2020, 12:31 PM
Jason Feuerstein's Avatar
I'm assuming the answer is no, but do you have the ability to read ABS codes? That would definitely help.
Old 04-06-2020, 01:36 PM
DCDisco2's Avatar
I agree. I do not currently have this capability, and fear that if I did it would exceed my ability to fix it anyone.
Old 04-06-2020, 02:05 PM
Brandon318's Avatar
If you need to rent the Nanocom to read them, mine's available for rent up in the Sticky section.
Old 04-14-2020, 01:16 PM
DCDisco2's Avatar
An update: it was the SVS switch, but the brake master cylinder was rusted out and leaking as well. All replaced, buttoned up, bypassed, and bled and it’s braking better than ever, with the amigos banished back from whence they came.
The following 2 users liked this post by DCDisco2:
boston4 (04-14-2020), coors (04-14-2020)
KC_Rover
06-12-2019 03:14 PM
LR03NJ
04-10-2016 11:24 PM
A boy and his Disco
08-30-2013 05:59 PM
No body
11-30-2012 02:32 PM
larson3000
07-30-2010 11:26 AM
Quick Reply: Flushed coolant = four amigos
