Flushing/Change Coolant
Take a good look under the hood before you do anything and order any fans, hoses, parts you need before you do this little project so that once you are done, you know it will be good to go for a few years and you won't have to worry about it again. If you haven't replaced anything yet, you will know what's up after spending all the time and money for this only to have the lower plastic assembly crack or bust and find yourself doing the whole process over 2 months later. Be thorough.
LR03NJ (01-31-2016)
I just did mine Sunday and removed the top hose (goes from the bleed T to the thermostat. I let the old coolant drain into something so I could dispose of it and then ran the water hose into that hose until pretty clear. I then used a special clamp for shutting off the flow for the hose to the water pump from the thermostat and that got the rest and forced it thru the radiator. When I was done and pulled the waterpump and thermostat (both replaced) it really cleaned everything out as there was only water in the block. My cooling system was super clean as far as sludge or particulates though so I think its been done before me as well.
meat
10-26-2015 10:48 AM
collin Barrows
08-28-2011 07:13 AM
Evian
09-10-2005 01:39 AM
