Flushing rad system
Old Jun 4, 2011 | 07:38 PM
silverfox's Avatar
Default Flushing rad system
Having some trouble locating the rad drain on my 1999 disco. I want to flush the system this evening. Any help is much appreciated.
Old Jun 4, 2011 | 07:56 PM
buick215's Avatar
What most people on this forum including me do is simply disconnect the lower radiator hose.
Old Jun 4, 2011 | 08:16 PM
lordmorpheus's Avatar
Indeed. There is no drain **** (I always giggle at that term) on these radiators. Just pull the lower hose.
Old Jun 4, 2011 | 08:38 PM
Don't waste your time, D2 radiators don't flush well if at all.
Take it to a radiator shop that can do an alluminum radiator, along with replacing the tanks. If it is over 100,000 miles and an estimate over $250, go buy yourself a new one from British Parts of Utah along with a new t/stat and coolant pressure cap.
When installing, do not use Dexcool, switch to Peak or one of the other coolants a make your engine happier.
Old Jun 4, 2011 | 08:46 PM
If you're just flushing the coolant for preventative maintenance, do it.
I think Mike was thinking of flushing because of a clogged system.
Old Jun 4, 2011 | 11:36 PM
silverfox's Avatar
Why would there be no drain ****! After all the vehicles I have worked on in my day this would be the first with no ****!
Old Jun 5, 2011 | 12:16 AM
thospb's Avatar
Because a drain in the Radiator is inefficient and the dealer technicians don't use them anyway. There are also drains on each side of the engine block but I don't think anyone uses those either, they are difficult to access.
Old Jun 5, 2011 | 05:47 AM
silverfox's Avatar
OK thanks all pulling the lower drain hose and doing a flush with some of that gunk system cleaner. then adding new antifreeze.
Old Jun 5, 2011 | 07:51 AM
If you just want to change the fluid make sure you use something other then Dexcool and make sure to replace the t/stat.
Old Jun 5, 2011 | 08:32 AM
silverfox's Avatar
Well I just flushed er out, replaced it with Prestone long life. Did not replace the T-stat. I could though if this should be done, it is working fine it seems.
