flywheel confusion 4.0-4.6
Old Nov 19, 2014 | 01:38 PM
dusty1's Avatar
ah ha! updated design.
Old Nov 19, 2014 | 03:10 PM
RicketyTick's Avatar
Yeah, I have flywheels from 4.0 and a 4.6 and they are different the way they bolt up. The two I have are different just like in Paul's pics. On the 4.0 the hub is separate the 4.6 it isn't.
Old Nov 20, 2014 | 06:29 AM
drowssap's Avatar
now for the $64k dollars question: which one's was breaking?
there were a couple post in the past about members finding cracked flywheels
Old Nov 20, 2014 | 06:45 AM
Paul Grant's Avatar
I've seen cracks in the flex plate (FTC4607) but I've not seen any damaged flywheel/gear ring parts.
Old Nov 20, 2014 | 06:48 AM
Paul Grant's Avatar
My guess would be that the earlier style of flywheel and gear ring was more prone to failure. Maybe that was the reason for the change in style?
Old Nov 20, 2014 | 07:11 AM
drowssap's Avatar
"'ve seen cracks in the flex plate (FTC4607)" you are correct it was the flexplate
Old Nov 20, 2014 | 08:32 AM
dusty1's Avatar
I saw a few pics where the flexplate had a nearly complete circle ripped at the holes.
Old Nov 20, 2014 | 08:35 AM
drowssap's Avatar
yuh, thats the one i was think of
Old Nov 20, 2014 | 09:20 AM
Yeah I have one of those flexplates ripped into two pieces. They are thin and I've read, but don't know if it's actually necessary or true, that anytime your in there put a new one in since they can have microscopic cracks beginning that you just can't see with your eye. Probably worth the extra $40 or so for piece of mind...especially if the old one has many miles on it. (flex plate that is).
About flywheels, I like the looks/feel/design of the 4.6 one best. It seems like it would be stouter but, don't know if flywheels give that much trouble anyway....maybe the ring gear.
Old May 24, 2023 | 08:03 PM
Discorama's Avatar
Originally Posted by Paul Grant
Okay, you have one ring gear, the one on the left with a part number of HRC2932. I seem to recall this coming out of a 4.0L. The one on the right is TPD000050 which came out of a 4.6L. The one on the left comes in pieces whereas the one on the right is a single unit. Parrt number TPD000040 also is valid for the ring gear. The flex plate will work with any of these units.
SO I have the choice between TPD000050 ('04 D2) and HRC2932 ('00 P38). People say they are the interchangeable, but if I take a closer look I notice a significant difference. For theTPD000050 the large gap in the CPS coding is about 120 degrees ahead of the dowel pin (clockwise), while for the HRC2932 it is about 120 degrees behind the dowel pin (clockwise). Are they really interchangeable?
