Flywheel cracking?
Old 06-19-2018, 10:15 PM
TaylorCadence's Avatar
Default Flywheel cracking?
Wondering if these are cracks forming?
And how do I manually turn the engine to rotate the flywheel and inspect other sides?
Old 06-20-2018, 04:31 AM
shanechevelle's Avatar
Cracks, idk.....
But you can use a prybar or big screwdriver on the teeth. They also make a flywheel turner... it's like a huge pliers.
Or you can disengage the fuel pump and bump it with the starter.
Old 06-20-2018, 06:08 AM
BackInA88's Avatar
I use the socket and breaker bar on the front pulley, removing the spark plugs makes turning it easier.
Old 06-20-2018, 07:43 AM
OverRover's Avatar
+1..… 15/16" socket and the engine will rotate no worries.
Old 06-20-2018, 07:47 AM
Sixpack577's Avatar
Yep, crank pulley...but I don't see any cracks in the flywheel.
Old 06-20-2018, 08:07 AM
The Deputy's Avatar
Received 1,165 Likes on 840 Posts
Don't see any cracks, either.
Looks like a little dust/rust residue from where the bolts are on crank/flex-plate...but see no cracks.
Brian.
Old 06-20-2018, 02:56 PM
sweet thanks
Old 06-20-2018, 03:00 PM
Brian.
Little rust it looks like yeah, I’m just nervous that maybe the cracks are underneath that ring that sits in the middle there. kinda like this one:
Old 06-20-2018, 03:03 PM
Which is the crank pulley, hah? And does tranny need to be in neutral? I’ll see if there’s anything on the other side
Old 06-20-2018, 03:20 PM
Sixpack577's Avatar
Auto trans flywheels tend not crack, ususlly only manuals from clutch wear and abuse.
If your torque plate/flex plate was damaged like the one pictured, you would definately hear it, especially when on/off the throttle or when it shifts.
Leave the transmission in park when breaking the crank pulley loose.
Quick Reply: Flywheel cracking?
