Fob advice?
Old 11-02-2016, 05:39 PM
Hephaestus's Avatar
Default Fob advice?
Hi all, thinking about buying one of these $130 key fobs on ebay. I talked to my local LR dealership and they quoted me $400-$500 for the key and programming. I figure I can get fob with barcode and then have them program it. Anyone had experience with this?
Old 11-02-2016, 07:47 PM
FloridaRover's Avatar
Which key do you have? I just converted my OEM 2004 D2 keys into these $9.99 eBay shells and they look 100% authentic
2 Button Remote Key Fob Case Shell for Land Rover Discovery 2 TD5 V8 Repair Kits | eBay
I had tried another cheap eBay FOB in the past but the key blade did not fit well into the plastic case, the kit I just recommended is a perfect (tight) fit for my key blades and even says Valeo on the back
Old 11-02-2016, 10:09 PM
BS50MGSXR's Avatar
bought a Nanocom for $400 and programmed two keys that came with the car when i bought the D2 used. also used it to bleed my brakes and it will read all sorts of functions on the vehicle. or find some one close by with a nanocom to program a key for ya.
Old 11-02-2016, 10:30 PM
Hephaestus's Avatar
Thanks for the replies. All I have is a metal key, bought it that way. The nanocom looks really neat. I already have an icarsoft and an ultra gauge, it would be hard to justify another gadget. Did you need the barcodes on the keys to program?
Old 11-02-2016, 10:36 PM
BS50MGSXR's Avatar
ya, there is a sticker on the back of the electrical board with a combination of letters and numbers thats used to program the vehicle to the key fob.
Old 11-02-2016, 11:50 PM
abran's Avatar
You need the barcode for the dealer to program and you need the sticker on the circuit board for a Nanocom or Autologic to code to your vehicle.
Put your location in your signature, maybe a member can help.
Old 11-03-2016, 12:25 PM
Hephaestus's Avatar
Great info, I'm in the south Seattle area. Thanks for all the help!
Old 11-03-2016, 01:22 PM
Dave03S's Avatar
I did the same as FloridaRover, nine dollar fob and used the same circuit board with a new battery. Also had a new key cut off the original as it was wearing out too. That took two tries, one at a hardware store where they failed, then at a lock shop which showed me how the hardware store failed.
Old 11-04-2016, 01:03 PM
squirt's Avatar
Since you don't have any fob at the moment, you'll need someone to interface with the car and sync a new one. There's a guy that advertises on my local craigslist selling the service, with a new key/fob for $130 out the door. Local folks with nanocom will usually do just the programming for $50.
Your other alternative is to go with an aftermarket keyless/alarm setup, but it will probably end up costing just about as much as your quoted prices in the end.
Best bet is calling up a local independent LR repair shop and see what it would cost to get a fob and have it synced. My guess would be $200 or less. The dealership is going to charge you more for the labor, and may give you a hard time about sourcing your own parts.
Old 11-04-2016, 06:03 PM
Hephaestus's Avatar
After calling every locksmith in the city I finally got a hold of the guys at Lamorna Garage in north Seattle. They were super helpful even recommended before I buy a key to stop by and make sure the truck is able to be programmed. If I provide the key fob they can do it for $50. Sweet! stay tuned...
Quick Reply: Fob advice?
