Fog Light Fuse/ Power
I removed my Britpart front bumper to sand down and refinish, it was getting rust at the welds. Ground it all down, primed, painted, looks great.
I mounted some small fog lights in the front recover hook mounts, when I re-installed them they worked for a bit, but then I touched the to wire wires together when I was putting it back together and shorted it I think. The 10 amp fuse under the dash is fine, I replaced it just in case. The binnacle switch does not light up, it did earlier. Any ideas on what I may have broken? The rear fog lights are fine if that matters.
Thanks for the help
Thanks for the help
