Fog Light Fuse/ Power
Old Sep 25, 2022 | 01:44 PM
redrover75's Avatar
Default Fog Light Fuse/ Power
I removed my Britpart front bumper to sand down and refinish, it was getting rust at the welds. Ground it all down, primed, painted, looks great.
I mounted some small fog lights in the front recover hook mounts, when I re-installed them they worked for a bit, but then I touched the to wire wires together when I was putting it back together and shorted it I think. The 10 amp fuse under the dash is fine, I replaced it just in case. The binnacle switch does not light up, it did earlier. Any ideas on what I may have broken? The rear fog lights are fine if that matters.
Thanks for the help
Old Sep 25, 2022 | 09:40 PM
greisinb's Avatar
It appears that the lights themselves as well as the light in the switch are all powered from fuse 3 under the hood so I would check that out first, shorting the fog light wires would certainly cause it to blow.
Old Oct 1, 2022 | 04:06 PM
redrover75's Avatar
Default Fixed!!
That was it!!
Thanks for the effort to look that up. It was nagging me after all the work fixing the bumper and rigging the fog lamps.
Appreciate it.
Old Oct 2, 2022 | 09:34 PM
greisinb's Avatar
Originally Posted by redrover75
That was it!!
Appreciate it.
No problem, it’s always a good day when a problem can be fixed a simple fuse replacement.
morris27
Apr 30, 2011 04:58 AM
djjakubik
Apr 3, 2011 08:52 PM
boldingm
Mar 11, 2010 08:42 AM
VikingDiesel
Mar 10, 2009 11:35 PM
mikemeyer0
Apr 1, 2005 02:03 PM
