Fog Light harness plug wiring
Old Aug 23, 2022 | 11:48 AM
Birdog's Avatar
Default Fog Light harness plug wiring
Purchased new bumper with fog lights from Atlantic British. The new fogs have a harness plug that won't plug directly into the existing plug on the D2. I was planning on splicing the old plug onto the new lights. However the wiring on the new lights is white and black and the OEM wiring is blue and brown. On the OEM plug which wire is the ground and which is the power?
Thanks!
Old Aug 23, 2022 | 12:41 PM
whowa004's Avatar
As I don't know off the top of my head either Rave should have that information or a quick test with a multimeter would tell you..
Old Aug 23, 2022 | 02:28 PM
nashvegas's Avatar
On the *vehicle side* harness plug, the ground wire is black and the power wire is blue w/ purple stripe.
This is for a 2000, should be same 99-02
This is for a 2003, should be same 03-04
Your pic is of the pigtail that comes off the fog lamp, yes? Just figure out which one plugs into which color of the above 2.
On the actual fog lamp, you should be able to plug it in either way. Doesn't matter on a standard incandescent light bulb w/ 2 connections doesn't care if you hook them up backwards... )but if the new lamps are LED's I think they actually care about polarity. Are these LEDs?
Old Aug 23, 2022 | 02:47 PM
mln01's Avatar
If testing with a multimeter, remember the front fogs will be powered only when the ignition switch is at Position II and the city lights or headlights are also switched on.
Old Aug 23, 2022 | 11:55 PM
greisinb's Avatar
If you are running incandescent fog lights the polarity doesn’t matter, but it’s probably good to know if you want to fit LED lights.
Old Aug 31, 2022 | 06:42 AM
Birdog's Avatar
Thanks for the replies fellas, I'll be checking it out this weekend.
Andy
Old Sep 1, 2022 | 06:04 AM
zski128's Avatar
I used these to wire in aftermarket lights to the factory fog light harness 6 months ago and no issues so far.
MUYI Fog Light Connector, 2 Sets...
Amazon Amazon
Old Nov 5, 2025 | 05:01 PM
Garrett Larrow's Avatar
MUYI Fog Light Connector, 2 Sets... https://www.amazon.com/dp/B07CSPGVFJ...p_mob_ap_share
sorry I know this thread is a few years old, but this connector, did you splice it into new aux lights and then it the end connected right with the factory fog light connectors on the d2, thus working with the switch inside the truck for on and off ?
LEDs or regular you used? Ty!
Old Nov 7, 2025 | 07:59 PM
thclark's Avatar
4wd High
Bumping - I'd also like to know,
Also - any issue with wattage output of new LED's on that wiring?
thx!
Old Nov 9, 2025 | 09:47 PM
thclark's Avatar
4wd High
For some closure around here...
I bought this:
Amazon Amazon
Deleted factory fog light connector plug (female) for the above and wired male end to my led fog light. Changed nothing else, works like a charm with stock buttons in the dash.
ZB-30
Aug 16, 2022 07:22 AM
ls1morethanyou
Apr 10, 2014 07:07 AM
Coyote
Apr 25, 2013 11:18 PM
ebg18t
Mar 1, 2012 07:21 PM
MagicBoxOwner
Apr 16, 2009 07:25 AM
