Fog light question
Old Apr 16, 2011 | 07:50 AM
  #21
jafir's Avatar
Originally Posted by garagepro
I installed a fog light kit from Atlantic British and connected to the factory harness, but they didn't light up. I called and found out there is a relay under the left kick panel that may not be installed.
Indeed my relay was missing, but after installing one - I still have no power to the fog lights. Checked the fuse and it's good with power at the fuse box.
Any suggestions?
It's a 94 DISCO
This is really a D1 question, but are you headlights on when you try the fog lights? You need to have your low beams on first. The fogs won't work if your headlights are off or on high.
Old Apr 16, 2011 | 10:56 AM
  #22
ajmille's Avatar
Do yourself a favor and bypass the O.E.M wiring and go after market wiring harness and relay's but use the O.E.M switch, I have a 2001 sd with the lights and for the life of me cant get them working.This is the easest rout. I have taking all my wires out of the looms and traced for bad grounds, broken wires, bad relays, and fuses, found nothing. The dealer ship told me I had to get the computer programed for $80..00, well the aftermarket kit only cost's around $20.00, if you take your time it can be wired up very clean. Good luck!
Old Apr 17, 2011 | 09:07 PM
  #23
garagepro's Avatar
Yes I did have the lights on. Believe me I have tried everything including checking all the wires. I also have the aftermarket installation kit, so I guess I will just install that. Thanks !
abran
Oct 1, 2013 09:09 PM
yeager6
Mar 14, 2008 01:46 PM
burtondr
Oct 20, 2007 05:19 PM
intellicheck16
Freelander
May 18, 2007 10:29 PM
Blizwinter
Freelander
Feb 22, 2006 10:06 PM
