Fog light removal.
I got a used disco with brush guard with fog lights installed. The rubber guard is worn but would like to remove the lights and use them. It has a sprocket like gear to mount it but not sure how to remove it from the mount. Anyone knows how to remove it. Is there a special tool for it? Thanks
You take off the bumper end cap. 2-3 screws on the inner edge of the fender well and 3 screws along the bottom edge.
Then I usually use a plastic pry tool at the front center edge of the cap and pry up, there is a small plastic forked tab that slides into the bumper. At the top there are 2 tabs that release from the bumper, gently negotiate the cap off.
Now there are 3 Phillips head screws at the front of the fog you need to remove, the one that has an access hole through the end cap is for adjustment, don't plaudits that one.
If it's not clear I can snap a photo of an end cap later tonight.
