fog lights?
Old Apr 3, 2009 | 11:50 AM
hollis's Avatar
Default fog lights?
what is needed to install fog lights on my disco if it did not come with it?
Old Apr 3, 2009 | 04:08 PM
AK Rover's Avatar
Are you talking factory fog lights or just basic aftermarket lights? Aftermarket lights are pretty easy to wire up. Just mount the lights under the front bumper and run a few wires. If you're looking for factory fog lights you'll probably have to buy a trim piece for below the bumper that is designed for fog lights.
I actually just installed a small set of aftermarket fog lights on my D1 using the factory fog light switch. Mounted on the lower bar of my brush bar where they are low enough to be effective yet protected by the bar.
Old May 25, 2009 | 11:16 AM
tango123's Avatar
So is it possible to use the factory installed 'rear' fog light switch(It came with my D1. It doesn't have the factory front fog light switch ) to run the wiring of a 3 pcs. aftermarket fog lights(aprox. 300 watts with a relay.)? I try not to use the aftermarket switch that came along with the fog lights if it is possible.
Old May 25, 2009 | 11:47 AM
gilder's Avatar
I'm told that you have to program the ecu to know that fog lamps are installed in order to use the factory switch. I'm going to test that theory tomorrow when my fog lamp switch and Hella Black Magics come in from AB. I'll let you know.
Old May 25, 2009 | 12:39 PM
tango123's Avatar
what I meant is, I have a rear fog light switch that is actually working. I was thinking of just trying to share the wiring of it and just use it to turn all the lights. (rear fog light and front fog lights(using relay of course) at the same time.). I just wanted to know if that is possible or would it burnt out the switch?
Thanks though.. let me know how your install turns out.
Old May 25, 2009 | 02:35 PM
tailchaser0527's Avatar
If you use a relay, there's no reason that u would hurt the switch.. A relay is meant to handle a larger load than the switch can handle. They also work well because you can run very small gauge wire from the switch, potentially saving a lot of money on heavy gauge wire.
I have 260 watts on my front bumper running off of my stock switch, with a relay.
Old May 26, 2009 | 06:44 PM
RoveringAgain's Avatar
Very interested in knowing the results of that test. Let us know!
Old May 26, 2009 | 10:09 PM
Princess's Avatar
This is a good idea with using the same switch and a relay. What is the procedure for getting to the switch wiring? Do you pull out the switch or get to the wiring harness below?
Snowdog
Apr 7, 2016 01:05 PM
Frank4
Nov 21, 2015 05:47 PM
abran
Oct 1, 2013 09:09 PM
jordamf
Aug 2, 2011 09:04 AM
mikemeyer0
Apr 1, 2005 02:03 PM
