fog lights burn up tail light fuse
Old Mar 28, 2005 | 05:26 PM
mikemeyer0's Avatar
Default fog lights burn up tail light fuse
When i turn on my factory fog lights in the air dam, the fuse blows and the tail light's and dash lights go off too. are they all on the same fuse or what. 98 discovery. anyone else have this prob and know what to do.
Old Mar 28, 2005 | 10:21 PM
Bait's Avatar
Default RE: fog lights burn up tail light fuse
Mike,
This is A common issue. Pop the bonnet and disconnect both front fog light connectors. They are located right behind the headlights. Then replace the fuse and turn fogs on. If fuse does not blow, connect one fog,then the other. This will tell you which fog lamp is shorted. Remove the suspect fog lamp assembly from the vehicle and disassemble to find the cause.
Good luck and let us know how you make out.
Old Mar 29, 2005 | 05:52 PM
mikemeyer0's Avatar
thanks for the help, i will give that a try
Old Mar 31, 2005 | 05:29 PM
mikemeyer0's Avatar
sorry guys, that didn't work, when i tested it like that it still poped the fuse (without both fogs pluged in) now what to try?
Old Apr 1, 2005 | 02:05 AM
Bait's Avatar
So Mike,
You have A 98 NAS Disco I that blows (what # ) fuse when the fog lights are turned on.
Old Apr 1, 2005 | 02:03 PM
mikemeyer0's Avatar
i will check what # fuse, it is under the hood, the one for the tail lights and inst. lights.
gillart
Jan 7, 2015 07:12 PM
abran
Oct 1, 2013 09:09 PM
Jameslandrover110
Defender
Feb 18, 2011 02:46 PM
VikingDiesel
Mar 10, 2009 11:35 PM
zoomlenz4u
Jan 15, 2009 01:35 AM
