Fogged up windows with coolant smell..??
Old Feb 22, 2006 | 03:10 AM
martini7's Avatar
8th Gear
Default Fogged up windows with coolant smell..??
Hi, tonight on the way to the store, I smelled coolant, and then the front passanger side window fogged up. After I parked, I didn't notice any leaking coolant? Any advice would be helpful, thanks.
Old Feb 22, 2006 | 03:03 PM
Jawbox's Avatar
Default RE: Fogged up windows with coolant smell..??
My first thought after reading your symptoms is that you probably have a leak in the heater core. This would bring coolant inside the cab which would cause the windows to fog up and for you to smell the coolant.
Old Feb 22, 2006 | 05:11 PM
martini7's Avatar
8th Gear
Hi, sort of my thoughts too. Any advice if this is the case? Immediate and long term? My last Rover, a Classic 92, I had the heater core break on me, now that was a mess. I ended up bypassing the heater for the short term, then later replaced.
Thoughts?
DiscoBenjamin
Aug 28, 2019 04:41 PM
Aferrell71
Jan 3, 2012 02:19 PM
NickMcAFP
Jan 15, 2011 08:35 AM
Northern Land Rover
Jul 31, 2010 12:17 PM
BajaXJ92
Feb 5, 2010 08:10 PM
