Four Jerry Cans on Safety Devices rack?
Old Nov 24, 2017 | 11:31 PM
dcaven's Avatar
Default Four Jerry Cans on Safety Devices rack?
Thinking about storing four Jerry cans at the front of my roof rack. I've got OME heavy duty spings and the front of the rack is closest to the center of the vehicle. I would not do this all the time. There are places I like to go where fuel is scarce. Is this a horrible idea? if so, why. Thanks.
Old Nov 25, 2017 | 01:34 AM
Richard Gallant's Avatar
That is a lot of weight up high, which is going to make you fairly top heavy. Really not recommended. If your rack can take it and you are traversing basically flat forest service roads, you should be ok.
But challenging terrain or higher speed could be interesting.
I carry 2 x 20 liter non vented cans inside, one by each rear passenger window with the window cracked. It has not been a problem in 7 years, but you need to check the cap seal every time you use them and have spares.
Not ideal but I don't like weight up high.
I have considered popping the spare inside and building a rack on the spare tire mount, that stacks and rests on the bumper but that is a spring task.
Old Nov 25, 2017 | 06:36 AM
The Deputy's Avatar
This type of extra gas can looks interesting. Makes center of gravity for can/liquid lower and less likely to get snagged on something. Plus, if you mounted them down the center of your rack that would minimize load shift and balance load better.
https://www.extremeterrain.com/searc...eType=Wrangler
If you already have regular jerry containers, I'd mount one to the rear door/ladder (if you have one) for off roading purposes. Carrying five gallons of fuel on my rear door during regular driving doesn't interest me, but for off roading...not a problem. I'm a cigar smoker...so carrying fuel inside is off the table.
Brian.
Old Nov 25, 2017 | 09:24 AM
dcaven's Avatar
Default Brian, what are you talking about?
Cigars and fuel go together just fine. I smoke a pipe on long drives and have similar concerns. Not sure what to do about the fuel thing. Other countries sell extended range gas tanks but not here. I would rather have it low than high. I carry a ton of gear in the rear already but may consider getting two on the rear and then just two up top. Not sure. Thanks for your input.
David
Old Nov 25, 2017 | 12:50 PM
Brian.
Cigar smoker too - with the no vent cans and GOOD seals not an issue - as long as you don't toss lit butts in the back
AtlanticBritish
Atlantic British
Oct 25, 2017 07:51 AM
dms6601
Off Topic
Jan 11, 2014 12:01 PM
Rover_Hokie
Jan 8, 2011 09:56 PM
hunter
May 11, 2010 09:26 AM
malibumike
Jan 7, 2006 12:17 AM
