Frame coatings
Old Oct 12, 2023 | 10:17 AM
dandswicks20's Avatar
Default Frame coatings
Hi everyone, got my first D2 a couple of months back. Just starting a frame swap. Any suggestions on what to coat my replacement frame with to keep it in good shape for years to come? Any other suggestions of things to do while it's pulled apart?
Old Oct 12, 2023 | 12:06 PM
Richard Gallant's Avatar
@dandswicks20 It is a yearly thing or fully galvanized frame. But for the outside POr -15 is often used but it is nasty stuff to apply, stay away from rubber under coats. The inside is the problem you need a good sprayable product.
Here is one article https://www.robisonservice.com/articles/RonR_waxoyl.php
Old Oct 12, 2023 | 12:28 PM
Thanks.... Not doing galvanized due to cost but have a really clean replacement frame, being from MA I want to protect against rusting from inside out. Appreciate the info!
Old Oct 12, 2023 | 02:35 PM
Extinct's Avatar
I like fluid film, they come with 360 degree spray nozzles on long tubes. Used engine oil is a known magic rust repellant so you use that too.
Old Oct 12, 2023 | 03:14 PM
zski128's Avatar
I vote for fluid film like Extinct. I am from MA as well so familiar with the rust struggle.
Old Oct 12, 2023 | 04:15 PM
gecko951's Avatar
Food for thought:
Old Oct 13, 2023 | 06:08 PM
H Hill's Avatar
Default Rust check is the answer
Don’t know if they have franchises in your area, but Rust Check is great!! Had it on my Peugeots (yes, odd cars before Land Rover!!) as well as long life VW diesels. Really works on new and used. A film type product developed in Canada. Love it!!!
Old Oct 14, 2023 | 04:44 PM
greggnvt's Avatar
Fluid Film
Old Oct 16, 2023 | 06:34 PM
Alex_M's Avatar
I'm always a fan of just plain old gloss black rustoleum. A nice heavy coat. You can get turbo cans now and it lays on quick. Salt and whatever washes off the gloss finish easy. Readily available and easy to reapply, and the oil base paint seals the surface up nicely while being less chip prone than POR15 and similar products.
Old Dec 5, 2023 | 08:58 PM
So the update is that I went with fluid film but keep getting the stuff all over me every time I use the hitch!
Brandon318
Mar 22, 2022 09:22 AM
MSGGrunt
Apr 24, 2020 10:12 AM
escott16
Apr 2, 2020 12:52 PM
D2#1
Jan 20, 2020 04:13 PM
ge234
Mar 30, 2019 12:39 AM
