Frame repair
Old May 3, 2021 | 02:17 PM
Anthony Gambale's Avatar
5th Gear
Default Frame repair
Hey all, I have to do some welding on the frame of my Discovery II. Other than disconnecting the battery is there anything else that I should disconnect?
Old May 4, 2021 | 12:02 PM
frostythor's Avatar
Yes disconnect your alternator and your ECU,
Old May 5, 2021 | 08:35 AM
SundayFunday's Avatar
I have done some extensive welding to my frame & have never disconnected anything aside removing the battery.
I think once I disconnected the ground to the block.. and forgot. Took me a day or two to figure out why it wouldn’t start.
Old May 5, 2021 | 10:59 AM
frostythor's Avatar
its easier to disconnect than find out after completing the job you have a problem, like a fried ECU your choice
Old May 5, 2021 | 05:03 PM
The Deputy's Avatar
The best thing you can do while welding...is keep the ground as close/clean/secure to the area that you're welding as possible. It keeps the "path" short. Usually, where folks run into problems, they connect the ground to a spot they've cleaned/ground down to exposed steel...then jump around welding all over the frame. Next thing you know, the battery ground cable becomes a secondary ground route and the welder uses that "path" instead of welder ground lead. Plus, the closer you keep your ground to work area, the better the penetration you'll get. Plus, keeping the ground "path" close...helps keep you from becoming a ground path.
l've probably welding on hundreds of vehicles over my forty years...and never disconnected battery ground or ECU...and have never smoked one.
Actually, l've only seen it once. But, the guy did exactly what l described. Clamped ground to steel front bumper and started welding behind drivers door. ECU bit the dust.
Old May 5, 2021 | 06:34 PM
5th Gear
Thanks so much, it was a big Help!
dwatterson1
Apr 5, 2021 08:34 PM
udibl
Jun 2, 2020 10:06 AM
escott16
Apr 2, 2020 12:52 PM
ge234
Mar 30, 2019 12:39 AM
1994discovery
Jan 1, 2008 10:24 AM
