If your headliner is sagging or peeling, this is an easy fix.
This unit has been professionally reupholstered and looks like new. New factory match sandstone color headliner material. Clean finish, tight fabric, and ready to drop in.
Full disclosure - minor imperfections/creases in a couple of spots. A solid 9.75 out of 10. - see pic.
I pulled the donner headliner out of a Pick n Pull in excellent condition. Stripped the old material off and coated the topside of the liner with white waterproof rubberized paint - Flexseal before it was reupholstered.
$690 OBO,
Local pick up only. I am in San Mateo, CA.
Saves you the hassle and cost of redoing yours.
Is the idea behind the flex seal on the top to prevent the headliner from being damaged from inevitable water leaks? If so, interesting.
Yes - that is the thought. I saw another post on this forum where someone applied flexseal to the top side for that reason. I figured I'd give it a go.
