Frickin' Hub Caps!
Old Sep 22, 2006 | 02:05 PM
Benhamtroll's Avatar
Default Frickin' Hub Caps!
Okay, I'm just about ready to pull out my hair over the little 'Silver Sparkle' hubcaps on my 2000 Disco.
Has anyone else had a problem with these thing falling out? I lost one about a year and a half ago. I replaced it (at $18), but now I've lost this replacement AND the one on the other end of the axle. I don't seem to be getting excessive vibration or anything, they just keep falling off.
Is there any way to prevent this?
TIA
Chris
Old Sep 22, 2006 | 03:46 PM
Default RE: Frickin' Hub Caps!
It is not Rovers fault the caps come of, it is your mechanic or your fault for using the wrong size socket when removing your wheels.
Have to use a 1 1/16th. 6 point socket to make sure that doesn't happen.
Mike
Old Sep 22, 2006 | 04:11 PM
I'm talking about the little silver logo caps that go over the bearing hub on the alloy wheels (I believe they were also used on the RR). Rovers North made the same mistake when they sent me one of the big black hubcaps the first time I had to replace one.
Old Sep 22, 2006 | 04:27 PM
Sorry I misunder stood which part you were talking about.
If, when you install them, you put a small amount of silicone gle on the iside clip surface they will not pop off.
Good luck,
Mike
Old Sep 22, 2006 | 04:30 PM
I'd thought about that solution, or something like it. Sounds like a plan to me.
Thanks, Mike.
Old Sep 23, 2006 | 12:29 AM
mr.47's Avatar
Hi
i stick transparent paper on the side of the cap. its lot cheaper
Old Sep 23, 2006 | 09:59 AM
ORIGINAL: Benhamtroll
Thanks, Mike.
Most of mine have now been on for at least 4 years, trust me it works well.
Transparent paper!!!!! Yes, that is cheaper and probably looks it.
Mike
Old Sep 23, 2006 | 04:56 PM
esaycho's Avatar
I've also found that Super Glue works fine as well. Shops are also still able to get it off just fine
sloppyjoe
Mar 11, 2009 07:36 PM
Randy Lover
Off Topic
Jul 14, 2007 04:09 PM
kerbse
Jun 5, 2007 06:21 PM
rickysrover
May 7, 2007 05:18 AM
farley5150
Feb 20, 2005 11:17 PM
