frist oil change
Old Dec 5, 2015 | 01:57 PM
kristofferzen's Avatar
Default frist oil change
Before the hecklers start....Im learning so play nice. I haven't changed my own oil before. I have a 2000 Disco II with 91,000 miles.
Was looking at:
Rotella 15 40
or
Rotella 5w-40
It's december and I live in PA which would be better? Also any good oil filter recommendations?
Thanks!
Old Dec 5, 2015 | 05:58 PM
drowssap's Avatar
The 5-40 is sythetic oil or dino oil iirc, so its more a matter of dino or synthetic oil.
Filters perulator fl1, wix 51515, mobal one 301 and quite a few otherr
Was looking at:
Rotella 15 40
or
Rotella 5w-40
Thanks!
Old Dec 5, 2015 | 07:57 PM
erick846's Avatar
Welcome to the club! Working on Rovers is easy--- you just gotta be confident.
So, if you're in PA i'd run 5w40 Rotella, probably a good idea.
A good, fairly common oil filter that many people use is the Mobil M1-301.
Old Dec 6, 2015 | 12:10 AM
DiscoCam's Avatar
Welcome to the forum!
I run Castrol GTX 10W-40 with a Mobil 1 filter year-round (Land Rover recommends Castrol). But it doesn't really go below 32*F here in SF. In PA, I would run 5W-40 in the winter because it goes below freezing. Rotella is a good brand too.
BTW: just get conventional oil for Discos. I haven't noticed a difference between conventional and synthetic on these trucks. Change it out every 3,000 miles.
Old Apr 21, 2025 | 09:18 PM
Elzot's Avatar
The advice to change your oil every 3k is about as valid as being advised to let your car warm up for 5 minutes before driving. It's not the '60's anymore. Engine and oil technology and manufacturing has vastly improved. Car warranties used to be 12 months/12,000 miles. There was a reason for that.
Old Apr 23, 2025 | 09:23 AM
Brandon318's Avatar
I can’t believe 2015 was a decade ago.
Old Apr 23, 2025 | 12:17 PM
Elzot's Avatar
Really. In my mind "Who's Next" was released a few years ago.
Old Apr 23, 2025 | 12:58 PM
jastutte's Avatar
considering these engines are pretty old tech and tend to run dirty, changing your oil every 3,000-5,000 miles is still pretty good advice.
i have a 2011 LR4 in the stable, run synthetic, and change the oil every 5,000-7,000 miles. LR4 owners have discovered that the 12,000-15,000 oil change parameters are a bit exaggerated and lead to (it seems) faster timing change guide issues.
Old Apr 23, 2025 | 01:21 PM
Elzot's Avatar
They are hardly old tech compared to engines that required those 3k changes. Personally, i don't wait for the 15k. But 3k is a waste of money and may actually be harmful. I'm not going to criticize anyone for doing what the manufacturer says. I may keep to a more frequent schedule but I'm not going to suggest someone is being foolish for doing otherwise.
Old Apr 24, 2025 | 10:07 AM
sqlbullet's Avatar
Saw a meme the other day: If Marty McFly went "Back to the Future" from 2025, he would have landed in 1995.
