Front ABS rain gutter Cover
Old Aug 11, 2017 | 03:41 PM
Sean Winter's Avatar
Default Front ABS rain gutter Cover
I need to insert a new rain gutter on the front passenger side. I'm a little hesitant to pop off the A pillar. Ordered some replacement rivets, bc I've seen that the center gets lost in the pillar.
Any suggestions on not removing the A pillar? Or maybe just the top rivet and sliding that gutter corner in? Or cutting the bottom of the gutter and just glueing the piece?
Thanks
Sean
Old Aug 12, 2017 | 09:48 AM
JUKE179r's Avatar
I removed the top rivet in the A pillar and slid the side gutter piece out while I was at Pull-a-part.
Old Aug 12, 2017 | 10:24 AM
Appreciate the info. I'll give it a try.
Thanks!
Old Aug 12, 2017 | 08:17 PM
If you have to repair the gutter, it's a must to remove the pillar. Just be careful and buy some rivets on eBay.
Attached Thumbnails Front ABS rain gutter Cover-screen-shot-2017-08-12-10.38.59-pm.png
Old Aug 12, 2017 | 08:22 PM
Watch the Atlantic Brit video. But after you pull it off, the metal clips stick to the pillar. You need to gently remove them and put them back on the plastic peice. Then snapped it back on. Add rivets to secure.
cosmiccharlie
Sep 3, 2015 09:48 AM
G150driver
Nov 13, 2014 07:20 PM
Chris-bob
Off Topic
Sep 8, 2011 01:44 PM
ek5usmc
Nov 3, 2008 11:18 AM
morfa
May 21, 2007 12:04 PM
